lucky1guddi
Camera Heating Issue
Thu Jun 20, 2019 11:40 am
Hello Sir
After 4PDA update to Android 8. I got one issue during making video. Every time I making video it show me an error after 3 minutes that Video will be stopped after 30 second due Camera overheating. Please Check the issue
Re: Camera Heating Issue
Fri Jun 21, 2019 9:28 am
Please perform a factory reset after the update, following this tutorial:
http://bbs.blackview.hk/viewtopic.php?f=192&t=334922
lucky1guddi
Tue Jun 25, 2019 4:46 am
I already apply the Factory Reset but it persists.
Tue Jun 25, 2019 1:56 pm
Ok, that means your phone is having an hardware issue.
You can try to contact your seller to have your phone repaired under warranty or.....
...you can try to replace the main camera by yourself.
Here you can find a spare camera module:
https://it.aliexpress.com/item/32997677942.html?spm=a2g0o.productlist.0.0.105847fbRjs9DX&algo_pvid=512808ca-bc77-4836-8ac2-06194cbab504&algo_expid=512808ca-bc77-4836-8ac2-06194cbab504-4&btsid=ffb16754-215d-4b3a-af49-0f43096f3800&ws_ab_test=searchweb0_0%2Csearchweb201602_10%2Csearchweb201603_53
