serioga
Very low speed connection on 5Ghz and 2.4Ghz
Wed Jun 19, 2019 6:32 am
Hi i have a notice regard wifi connection on 5Ghz and 2.4Ghz, Both Phones Tested(on both persist problem) Blackview BV9500, BV9500Pro
Routers that was tested with phone: Asus RT-AC87U, Tplink AC1200, Tplink AC5400, and 4G Netgear Nighthawk M1 MR1100
Connection near router at 5Ghz always not more then 135Mbits by the way other phones that i have have connections about 470-800Mbits
and 2.4Ghz only 65Mbits, i think this quite not normal for this device, when will be updated driver and when our bv9500 will support normal speeds
https://www.tp-link.com/ru/home-networking/wifi-router/archer-c5/
Re: Very low speed connection on 5Ghz and 2.4Ghz
Wed Jun 19, 2019 10:23 am
Hi there!
BV9500 Pro supports Wifi 802.11 a/b/g/n.
As you can see from the table in attachment, the speeds you get can be considered normal.
wifi speeds for article.png (9.96 KiB) Viewed 2568 times
Tech Addict
Wed Jun 19, 2019 10:32 am
Man. I've got to get AT&T to upgrade my router. I've been 54Mbit 802.11G since it was put in like 6 years ago.
Of course I'm only getting 12Mbit into the WAN side of things so it's not like it would help much.
serioga
Thu Jun 20, 2019 8:43 am
You can ask each user and they will say same, this problem persist on all edition of bv9500pro and bv9500, The routers I use are modern top segment , let your engineers check the wifi connection speed
Thu Jun 20, 2019 9:37 am
Please read my previous post carefully. ;)
serioga
Fri Jun 21, 2019 5:27 am
So you consider that 135Mbits on 5Ghz is normal speed connection?
Fri Jun 21, 2019 9:42 am
Yes.
