nass1470
Audible notification sounds
Wed Jun 19, 2019 6:23 am
I have to say that I am really happy with my BV9500Pro.
The only glitch that I could not fix is: how can I Turn Off the notification sounds when I am using the wireless headphones?
And what I mean is that I am in the Bus listening to my music (laud) and I get a notification from an app (ex. WhatsApp, AnySee etc) and the Phone is very loud. How can I fix this? In I Turn down the volume, then the music volume goes down AS well.
Thank you!
BR,
Tudor U.
Re: Audible notification sounds
Wed Jun 19, 2019 10:30 am
Just press the volume button, then lower only the notification/ringtone volume from the dropdown menu. You have to select the notification/ringtone volume from the "volume" menu.
nass1470
Wed Jun 19, 2019 2:58 pm
AS you can See in the Photo (attachment) there is only General volume.
What now?
Thanks.
serioga
Thu Jun 20, 2019 9:00 am
Is it possibility to make apart volume modification of the notifications and calls?
Thu Jun 20, 2019 9:39 am
nass1470, just slide down the RING volume with your finger, or press on the "bell" to silence ring/notifications.
Thu Jun 20, 2019 9:40 am
That's what the RING slider is for. ;)
Tech Addict
Thu Jun 20, 2019 10:32 am
What Serioga refers to is how other phone manufacturers have the option in settings to separate ring volume and notification volume. There are times it comes in handy, actually.
dario
Thu Jun 20, 2019 1:47 pm
.... and I confirm that to get the possibility to adjust the notification volume  separately from the phone one would very useful.... as well as the "double tap" option to lock/unlock the phone  ...
serioga
Fri Jun 21, 2019 5:26 am
Tech Addict, Yes exactly)
Fri Jun 21, 2019 9:46 am
I personally find the actual system quite useful ;)
