BV9700 Pro Has Passed MIL-STD-810G!
Thu Jun 13, 2019 10:08 am
BV9700 Pro is MIL-STD-810G Certified. The phone has passed all the tests, which strictly comply to the MIL-STD-810G tests methods.
BV9700 Pro has been tested under vibration tests, mechanical shock tests, drop tests, as well as  temperature tests of -55ºC and 70ºC. After the tests, the BV9700 Pro had no change on appearance and function was normal.
