Brief specs:
19:9 5.84’’ FHD+ IPS Full Screen
Helio P70 Octa-Core
6GB Ram+128GB Rom
16MP Front Camera
Samsung 16MP+8MP Dual Rear Camera
4380mAh Quick Charge
Android 9 Pie Powered by Al
Night Vision Camera
Ultra-Light Sensitive
Air Detection Air Quality & Pressure Detection
Heart Rate Detection Blood Oxygen Heart Rate Monitor
Body & Strenght:
Engineered with industry leading precision and backed by harsh standard certification. Tested in all conditions and from -30 to +60°C, shrugs off muddy drops and rocky trips. BV9700 Pro can withstand relentless pounding, pressure and force. On the job site, in the field or in search of adventure, this Military Standard 810G device is an extremely rugged and reliable mobile solution. Have confidence your phone will cope with heavy downpours or a muddy trail and will continue to work for you, making sure you're connected at all times. Its stylish design makes it a piece of outdoor gear that fits the rest of your life too.
Take control and stay connected with a phone that's tough and durable enough to keep up with you. The four corners internal structure of the BV9700 Pro is reserved for impact buffers. Its fuselage is covered with elastic industrial soft rubber. Two sides of the phone are reinforced with anti-wear titanium aluminum alloy. They complement each other. Achieve 360-degree all-round collision - mitigation.
BV9700 Pro passed IP68 test, it can handle depths of even 1.5 meters for 30 minutes without any consequences. The touchscreens on Blackview smartphones are equipped with innovative wet finger tracking technology, meaning you can use the touchscreen as normal even when wet.
1.5M Drop Proof IP68 | 1.5M Waterproof 99% Dust Proof MIL-STD-810G
Special features:
VOC Air Quality Detection
Indoor air pollutants, or more specifically Volatile Organic Compounds (VOCs), include a large range of chemicals and substances. Prolonged exposure to VOCs can result in a range of health issues, including headaches and dizziness, irritation to the eyes, skin, nose and throat, and respiratory problems. The VOC detection sensor, which is capable of detecting volatile organic compounds, including both human-made and naturally occurring chemical compounds that are harmful to your health. Avoid breathing too much harmful gases from newly renovated rooms or air-contaminated outdoors. Measure temperature, humidity and the levels of indoor air pollutants in your environment
Integrated Blood Oxygen Heart Rate Monitor - Your Exclusive Sports Butler
Blackview is deeply concerned with the health of our user. That’s why BV9700Pro features the first-ever built-in heart rate monitor in rugged phone industry. The heart rate and blood oxygen value are measured by pressing the finger in the monitor. It obtains the user's heart rate data by detecting the number of pulses per minute of the blood vessels on the user's finger. Detecting and analyzing your personal heart rate blood oxygen before, during and after exercise can understand the exercise intensity and effort, and facilitate the user to adjust to their own exercise conditions, makes tracking your health and fitness goals a lot easier. The built-in pedometer also helps track your steps and calories burned.
External Night Vision Camera
The BV9700 Pro’s external camera is equipped with a Sony STARVIS IMX291 ultra-light sensitive cmos sensor, special design for low light and night scenes. The individual pixel size is up to 2.9um, 2.6 times the phone's main camera sensor. Light plays a huge role in photography. With the increase of pixels size, more light enters individual pixels. And together with ultra with angle big aperture 6P structure lens, your phone instantly turns into a night-vision unit, easily capturing the wonderful moments in the dark.
Inside....
The Most Intelligent Processor Ever
AI Master P70, Rugged Phone Debut. Helio P70 use the 12nm FinFET production process combined with CorePilot 4.0 provides class-leading performance and power-efficiency. So that the system does not hang when you are immersed in a movie or game, and multitasking becomes faster and easier.
Lower Consumption, More Efficient Cooling, Game Laggy Optimization.
Fast-lane performance with 6GB RAM + 128GB ROM
The combination of a generous 6GB RAM plus a 128GB ROM unleashes the full operating potential of the BV9700 Pro and boosts app opening speed. Plus, we've optimized the system to work seamlessly with Arena of Valor, PUBG:Mobile and more for your immersive gaming pleasure.
LPDDR4X RAM | EMMC 5.1 ROM | 256GB Expansion
Onboard cameras:
Dual Rear Camera, Shoot as an Artist
The Samsung® 16MP+8MP dual rear camera, paired with an advanced image processing algorithm, you can shoot richer photos with remarkable detail. Together with AI beauty technology, it also offers studio-quality portraits with bokeh effect to make you look like a star. In addition to photos, the multi-frame image stabilization technology makes your videos more fluent and vivid.
16MP Front Camera, More than a Beautiful Selfie
The 16MP front camera makes your selfies clearer even in various environments. Also, the wide angle and large aperture configuration captures extra details for more impressive photos. Al Face Beauty detects your gender, age, skin tone, skin texture and even the lighting conditions around you. And its customized beauty enhancement effects are all dedicated to emphasizing your unique and natural beauty.
Display:
With integrated bezel-less design, BV9700's large 5.84’’ FHD+ IPS seamless fullview display can be operated easily with just one hand. See more of what you want. The screen provides 15.5% more viewing area than standard 16:9 phones. The massive 85% screen-to-body ratio is made possible by a reduced top bezel compared to the previous generation FullView display.
19:9 Aspeect Ratio 5.84"FHD+IPS 85% Sreen-to-boby ratio
Battery and charging:
4380mAh Big Battery, Say Goodbye to Power Anxiety
Big battery, long battery life. With such a large amount of power right in your palm, redefine the business flagship configuration, you can easily get rid of power anxiety.
287 hours Standby 26 hours Call 15 hours Video 8 hoursGaming
Fast Charging with or without the Cable
10W wireless charging. Charging efficiency increased by 30%. Charge faster. Compatible with all Qi wireless charging standards. Use the wireless charger at the airport, the coffee shop, or wherever your travels take you. While charge with the cable, MediaTek Pump Express 4.0 fast charging technology is kicking in, enable fully charged within a very short period of time. Always ready for challenges.
And... the rest!
Multifunctional NFC
BV9700 Pro now can replace your bank card, bus card, and door card in one device with the latest generation NFC module. It is compatible with the Google Pay, fast, simple way to pay in millions of places – online, in stores, and more.
Barometric Altimeter, Good Friend of Climbing
The BV9700 Pro is equipped with a barometric altimeter that can be used to determine the altitude at which the phone is located. This is a very useful feature when doing activities such as climbing or rock climbing. In addition to presenting information about altitude, pressure, etc., this sensor can also assist GPS for more precise positioning.
Extreme Speed Fingerprint Unlock
Side of the BV9700 Pro is equipped with a fingerprint recognition sensor, which can be unlocked instantly by tapping the fingertips on. You can also use it to make mobile payment, enable shortcut function, etc. Extreme speed fingerprint recognition is not only more convenient, but also a sense of security that is worth entrusting.
Instant Face Access
Just activates the screen and Face Access unlocks your phone instantly. Accessing your phone has never been so simple and so futuristic.
Night-time access / Facial features in just 0.1 seconds.
GPS, Glonass, Beidou
3 Mode Navigation, Exceptionally Accurate Positioning
BV9700 Pro is our first ever rugged phone equipped with 3 mode positioning systems. By using GPS, Glonass, Beidou 3 channels signals in coordination, accuracy is improved to unprecedented levels.
Android 9 Pie, Powered by Al
Android 9 harnesses the power of artificial intelligence to give you more from your phone.
Now your phone is learning your preferences as you go. Your experience gets better and better over time, and it keeps things running smoother, longer.
