Fresh A5 ROM in July
Thu Jul 28, 2016 7:43 am
There are two roms that you need to select when you install it.
Check your firmware vision number of your device.
If the number include "SD", such as A5-C1-Blackview-SD-Q20160701 then
you need the ROM A
ROM A download site : https://mega.nz/#!6x8yWahR!KrgzBBxax3a_ ... P_Tf3-_oJM
If the number do not inlude "SD", such as A5-C1-Blackview-Q20160629, then please
you need the ROM B
ROM B download site :
https://mega.nz/#!uk8FEajI!LubobIiiQsqd ... wOFuo9Zbrs
Please check carefully the firmware verison number before you do a ROM flash because the wrong rom will cause a
huge demage to your device.
Best regards,
Admin
Blackwalker
Re: Fresh A5 ROM in July
Thu Jul 28, 2016 11:31 am
Thank you very much. Was waiting for this one.
But were can i check firmware vision number of my device?
Fri Jul 29, 2016 6:04 am
you can check your setting menu.
Best regards,
Admin
smarthousesys
Sun Jul 31, 2016 11:16 am
Hi Admin
Can you please give us a Clear and complete explanation of the correct procedure to update the Blackview A5 ROM. Is it via the the PC method or via
the settings/wireless update/local updates option or what ??? Regards
kireerik
Mon Aug 01, 2016 7:02 am
I have successfully installed ROM B, but id doesn't boots up. I have also tried ROM A.
I could re-flesh the previous old ROM B, so my phone is working currently. My current build number is: A5_C1_Blackview_VO.X_20160503
Could you please upload a fresh rom which is working?
Thank you for your assistance in advance!
Mon Aug 01, 2016 7:14 am
smarthousesys wrote:
Hi Admin
Hi ,
This Rom can be just flashed via PC. We now do not have flash manual for this model , but have similar flash manual for
other device, which may be a reference.
Best regards,
Admin
Mon Aug 01, 2016 7:19 am
kireerik wrote:
what is the screen resolution of your device ?
Best regards
Zandyzhang
Cane
Mon Aug 01, 2016 5:32 pm
Will this new ROM be available in OTA update form?
smarthousesys
Tue Aug 02, 2016 10:49 am
Hi
Do both the ROM A and ROM B links actually access identical files. SInce the names are the same and the name has HD in it I assume
is for the NEW screen A5 version . I have the original A5 screen 480x854(bought in May).
Regards
rebecca
Wed Aug 03, 2016 2:41 am
I have 854x480 screen, which rom to use
