I am having problem with the touch sensitivity is low and i cant change it
I only have the pre installed screen protector on my screen
So we want some option to increase
,And the other problems is Multi touch,
I can't use more than 2 fingers
It only work when i take a screenshot by dragging 3 fingers on the screen,
I had tried multi touch programs
And the top number of fingers was 2
But when i go to developer setting and i enable the (show finger clicks) then i can see 5 on the screen but its only 2 that really works (first two)
Touch screen software massive problem
Specially for the gamers who use the bv9500 pro device
I've been suffering
These problem since i got the phone
Can you just fix it
I didnt pay 450$ to deal with problems that can be fixed easily, just like these one
,Plus the sensitivity is a bit low
And to let you know
These problem is on all the bv9500 pro phones
Not just in my device
You can tell that the problem isn't a hardware problem by watching these video that i made
https://youtu.be/g99sVPzIHoE
##Important informations before watching the video:
-The white dots is my finger taps.
-the other circles is how the phone respond to it.
I was thinking that the problem was a (GPU) problem because the screen was stuttering when i play fps games just like how the touch does in the video above (the exact same way)
We need a solution for these problem
