zimzia
OTA 20190430v5 does not install
Sun May 26, 2019 1:37 pm
Hello, I downloaded updates OTA 20190430v5, after pressing "update" does not start, nothing happens
BV6000
Re: OTA 20190430v5 does not install
Sun May 26, 2019 4:20 pm
not to me. Try to factory reset...
i don't know if is possible using flash tool
zimzia
Wed May 29, 2019 5:25 am
Factory reset does not help, I still can not install
zimzia
Wed May 29, 2019 8:04 pm
Solved, copy the zip file from the SD card to the phone and use local update.
ConkerVCL
Sat Jun 01, 2019 4:05 am
Cambie el idioma a ingles y listo
