And1
p6000 overheat when charging
Fri May 24, 2019 11:23 am
good day
i buy this blackview p6000 two days ago, what i notice is when i charge it overheat. is this normal with p6000? because im quite worried. should i be alarm with it?
hoping for your response
thank you.
Re: p6000 overheat when charging
Fri May 24, 2019 7:32 pm
If the phone truly overheats, it will shut off (or reboot) automatically. So, you shouldn't worry about that. ;)
And1
Mon May 27, 2019 7:51 am
thanks for the response
AERO
Mon Jul 22, 2019 10:48 am
I have the same. I am used to it. It's because of the fast charge.
I think the best is to not use the mobile when it's in charge. That's it.
