Neville
Message and missed call notifications no longer work
Wed May 22, 2019 11:08 am
The 9600 Pro stopped giving missed call and TXT dots on icons after first update.
I expected latest update to correct this but it hasn't.
Please fix urgently.
Kagawan
Re: Message and missed call notifications no longer work
Wed May 22, 2019 7:59 pm
Use alternative launcher maybe can fix your problem.
csewell
Thu May 30, 2019 6:28 pm
I'll be darned, I thought it was just me. After this last update, no notification badges appear for SMS/MMS messages or phone calls. If you reboot the phone with outstanding notifications for either, they show up then.  I am using the Microsoft Launcher, but the same thing happens with the stock launcher.  No other app seems to be affected; they all show notification badges properly.
Neville
Thu Jul 11, 2019 5:03 am
SOLVED. The update simply switched notifications off. To re-enable go Settings/Apps and Notifications, find the Launcher app and re-enable dots.
csewell
Thu Jul 11, 2019 10:13 am
Notifications and dots are turned on for Launcher, Microsoft Launcher (default launcher), and all apps. But the phone app and text app are the only apps I've noticed that DON'T show any notification badges.
