Fbodymatt
Network Connectivity Issues
Tue May 14, 2019 10:13 pm
After I installed my SIM card into my new phone, the only connection it had with the network was data. It was scrolling across the top of notification bar that it was connected to Verizon but only had a "(Data only connection)". I tried rebooting the phone, a different sim card that is known to be good, tried the other sim card slot, made sure everything was updated, checked the network preferences to make sure it was finding the networks, tried both open roaming and non roaming, drove to another known good cellular area to make sure it wasn't the tower I was on. And I'm still having the same issue. It's showing full service and 4G connectivity
Re: Network Connectivity Issues
Wed May 15, 2019 4:19 pm
Hi there. Do you mean you can surf the web with your data connection but you can't call?
Fbodymatt
Thu May 16, 2019 9:45 am
Exactly. Can't call or send texts, but internet is fine.
Thu May 16, 2019 9:53 am
Where are you living and what's your phone carrier?
Fbodymatt
Thu May 16, 2019 11:20 am
USA Verizon, bought the US version
Thu May 16, 2019 6:39 pm
Unfortunately it looks that your BV6800 Pro isn't the US version one, actually.
As you can see here, the non US BV6800 Pro, with the Verizon carrier, will let you only surf the web (using 4G), but not calling (2G-3G).
https://www.kimovil.com/en/frequency-checker/US/blackview-bv6800-pro
Fbodymatt
Thu May 16, 2019 9:09 pm
So how do I go about getting the correct version?
Fri May 17, 2019 10:57 am
You'll have to contact your seller for that.
Fbodymatt
Fri May 17, 2019 12:24 pm
Ok. Ordered from blackview, off their site, and have the order number that shows they were ordered as us phones. Guess I'll get ahold of them and wait another three weeks.
Users browsing this forum: Google Adsense [Bot] and 2 guests
