Ragheed88888
Bv9500 pro massive problem
Mon May 13, 2019 2:38 am
The multichannel screen problem at games like pubg
That mean the screen stutter for 1 or 2 times for 1 sec while turning in all first person shooter games
And that happens Frequently
We need to fix these in the new update
I payed alot of money to get good experience at gaming
I had the bv6000 before that and it was good at gaming and i didn't get any problems at gaming and thats why i bought the bv9500 pro
If fixing the multichannel problem can effect the resolution
Its no problem
We need the smooth game play more than any other effects
You can see the problem at these video https://youtu.be/FLunfrwyLtw between 00:40 and 00:45 and there are some comments about it
But its happening in the bv9500 pro
Re: Bv9500 pro massive problem
Mon May 13, 2019 3:21 am
We have forwarded it to our quality manager/
Ragheed88888
Wed May 29, 2019 4:46 am
Just realized what the problem iw
Its all in the touch and how the system respond to it
And these is what makes the screen stutter in the fps games like pubg...or any of these type
You can see in these video here:
https://youtu.be/g99sVPzIHoE
Ragheed88888
Thu Nov 04, 2021 7:50 pm
You are the worst company ever , its been 3 years and you didn't fix it , and you didn't post an update , an advice don't buy blackview
bpz1970
Fri Nov 26, 2021 9:25 am
Blackview abandons its customers. There are no security patches or updates anymore. I won't buy something from this brand anymore.
