The WiFi on the BV9600 Pro doesn't work worth a darn in mesh networks where you have 2.4GHz and 5.0GHz bands with the same SSID. This is supposed to allow smooth WiFi roaming around a home, but at random it will disconnect and reconnect multiple times and eventually disconnect entirely with messages NETWORK_SELECTION_TEMPORARY_DISABLED, [color=#454545][size=100][font=Hind, sans-serif]NETWORK_SELECTION_DISABLED_ASSOCIATION_REJECTION (developer mode, verbose WiFi info). I have to keep my mobile data off because I will suddenly notice I'm using that instead of my WiFi, eating into my mobile data plan. After that, nothing can get it to connect to the SSID again normally. Sometimes turning Airplane mode on and off gets it working, sometimes a reboot is needed. Not only that, the signal strength will fluctuate wildly even when you're standing right beside the access point.[/font][/size][/color]
This happens on both BV9600's I have.
Is Blackview aware of this problem? Is there a fix in the works?
