Kagawan
How to downgrade firmware.
Mon May 06, 2019 2:13 am
Sorry but can someone tell me how to downgrade bv9600 pro firmware? since the latest firmware cause many problems like fingerprint unresponsive, pin/pattern 'wrong' but actually i entered the exact true pattern, sometimes phone restart automatically.
why blackview produce this great phone but very bad software quality and bad customer service.
Re: How to downgrade firmware.
Fri May 10, 2019 3:47 am
Sorry. Only upgrade. No ways to downgrade.
Kagawan
Fri May 10, 2019 12:52 pm
So when you release the latest firmware upgrade? Too many bugs right now. Please fix the bugs, and upload the latest firmware.
carabao
Tue Aug 13, 2019 8:42 am
I think the downgrade is possible but you have to go through the recovery menu unless bv blocked this possibility. My knowledge is limited in this area, it should perhaps turn to other sources more competent for this type of operation. But it is a very risky operation.
serg2327
Tue Aug 13, 2019 11:35 am
carabao
Tue Aug 13, 2019 11:46 am
Warning
Android 9 for bv9600pro may 2019 (processor P70)
Android 8 for bv9600pro Nov 2018 (processor P60)
serg2327
Wed Aug 14, 2019 3:05 am
carabao wrote:
Предупреждение
Android 9 для bv9600pro может 2019 (процессор P90)
Android 8 для bv9600pro ноября 2018 года (процессор P60)
 (Процессор Р90) -MediaTek MT6779
(Процессор Р60) -MediaTek MT6771
and we have the same "MT6771_Android_scatter" in two firmware. so this may not be true
I installed android 9 on my copy that was sold with android 8.1.
I also managed to repair mobile communications for old smartphones. Right now I'm using Android 9 on my smartphone very well!
I gave a link to the manual and firmware, but it is, of course, on a Russian resource, so not everyone can understand this. it is not so easy
And once again, a rollback to Android 8.1 is possible! You just need to install it using the SP_Flash_Tool  in the "firmware / update" mode
And those who flashed the smartphone in the "Format + Download" mode, they all lost NVRAM and now  they have destroyed IMEI numbers!
Recovery is possible, but it's not as easy as it sounds! First of all, you need to roll back to android 8.1
BV6000
Wed Aug 14, 2019 6:46 pm
serg2327 wrote:
carabao wrote:
Предупреждение
the problem of that forum, are the captchas and email... i tried but for me, its impossible
carabao
Wed Aug 14, 2019 8:26 pm
Why are you talking about email or captcha? The only limitation of this forum is that it takes a certain number of messages before you can post and send private messages without restrictions.
csewell
Wed Aug 14, 2019 10:28 pm
Actually to download anything from the site I think you need to sign up. The sign up captcha is numeric but it's spelled in Russian and doesn't translate which makes signing up difficult. This site might help:
https://doorsgeek.blogspot.com/2015/08/ ... l.html?m=1
It still took me a long time to solve the captcha.
