Chiogros
GSI Rom (try to success)
Thu May 02, 2019 1:02 pm
Hello world!
Like lot of us, I dislike stock rom that comes with 6800.
I've seen that thanks to Treble Check app, this stock rom could support GSI roms ! 8-)
I've tried to install one of them to get a custom, clear, recent, pretty rom but I get stuck : try it yourself and give tips if you success !
Here you go the steps I've crossed.
  • So I getting back to phhusson GSI list and have choosen Ressurection Remix pie version :geek: (A partition, cuz on the Treble app, it's written that's 6800 is A partition and not A/B)
  • Thanks to SP Flash Tool, I've burned system partition with the RR.img instead of stock system.img.
  • Reboot, black screen and a [size=85]little fastboot was wrote in the bottom left. (multiple reboots gave the same result)[/size]
  • So from my cmd on pc, I did :
    fastboot oem unlock
    (necessary for next steps, don't forget to go to enable OEM Unlock in Dev Options on your phone) and followed instructions on phone
  • Then
    fastboot erase system
    fastboot erase userdata
    fastboot flash system RR.img
  • And to finish I reboot and I get bootanimation (yeaaaaaah)... to much bootanimation because I get bootloop :twisted:
So do somenone get some ideas to bypass the bootloop ?
Thank for you help !
Re: GSI Rom (try to success)
Thu May 02, 2019 9:02 pm
I'd like to underline that flashing an unofficial Rom may brick your phone, void your phone's warranty and/or breach your data/privacy.
Users browsing this forum: No registered users and 18 guests
