bigbang63
I loose the camera for selfie
Mon Apr 29, 2019 2:49 pm
hi everybody, I have a BV8000pro since 1 year and last month the camera for selfie don't appear when i want to use it with open camera  !
I open the phone to verify the connection with the camera but nothing is wong .
What can I do ?
Re: I loose the camera for selfie
Mon Apr 29, 2019 8:04 pm
Firstly, please perform a factory reset and report back.
bigbang63
Tue Apr 30, 2019 6:43 am
thank you but i don't want to do a factory reset because I have many application installed and it tooks a lot of time to reinstall.
Is there another solution to test it? have you ever ear about this problem?
Tue Apr 30, 2019 7:37 am
Performing a factory reset is a mandatory step to rule out if such issue is software or hardware related.
Iv@ng33
Wed May 01, 2019 7:33 am
What can I do ?
Hi, this is a know issue. As said perform a factory reset. But some times this is not enough, you have to reinstall the rom. I had this problem with Android 7 and 8.
An other solution (worked for me) is to install "Camera_media.hd.photo.selfie.camera.apk". I don't know why but with this apk (Only this one, i have try about 20 apks) both mode are working... By my side the original camera apk has disappeared. This is a temporary solution. If you want to backup all your apps, Titanium will do a nice job ;) you can do a update.zip and you can flash it after factory reset or rom flash. I hop it will help you.
bigbang63
Thu May 02, 2019 7:36 am
What can I do ?
Thnak you very much I will try your solution, where can I find the camera media hd photo selfie camera apk?
thanks a lot
Iv@ng33
Thu May 02, 2019 1:29 pm
bigbang63 wrote:
What can I do ?
thanks a lot
I don't remember the exact name on the store, but https://mega.nz/#!hDw02ChR!Xb_bMA9BobBe1yR5Y6SE9vpQQnpVom8l8XH3z8-jsss
bigbang63
Thu May 02, 2019 9:55 pm
thank you very much for the link, I downloaded the apk and installed it, but it's the same , impossible to shoot photo with the front camera ! I 'll try the factory reset.
Iv@ng33
Fri May 03, 2019 7:43 am
Sorry, it worked for me... I think a factory reset is required, good luck ;)
bigbang63
Mon May 13, 2019 8:34 am
hi everybody!
I need my selfie camera , so because i can't get it back by the means mentionned above, I'll test the factory reset but before i must use titanium backup, but my phone must be root,  how to do it? have you a simple method?
thanks !
