So, since the latest update, I now find the BV9500 no longer allows Bluetooth devices to pair with it. The problem occurs when it asks for a pin input from either device to verify credentials. For some reason, it kills the pairing request milliseconds after asking for a pin, so there's no chance of verifying the pin. This happens regardless of which device initiated the pairing request. Pairing via NFC works fine. I'm even more annoyed because I factory reset, the pairing still doesn't work, and now I'm not even able to pair with the devices I was paired with before the reset.
Hopefully this can be fixed easily and quickly.
