BV9700 Pro: a new flagship phone is coming!
Tue Apr 23, 2019 10:10 am
Here you can see all the salient features of our new flagship phone:
  • New Rugged Body Design: more Water/Dust/Shock Proof. Treated with the material of waterproof ring / waterproof membrane to prevent water from penetrating into the mobile phone. Safely used even being underwater 1.5m for half an hour. The mobile phone's various accessories are equipped with a waterproof ring / waterproof membrane to prevent water from penetrating into the mobile phone, nano-level waterproof material is used.To ensure its waterproof, the product is tested before each delivery. The BV9700 Pro has been tested and can be used safely after being underwater 1.5m for half an hour. The four corners are the most vulnerable when the mobile phone is dropping. The BV9700 Pro's four corners and the back are made of elastic rubber with high elasticity and wear resistance to avoid the impact of the mobile phone falling, the material is also hand-friendly and preventing slipping out. The BV9700Pro has anti-wear titanium alloy on both sides, which more firmly binds the front and rear covers together to make the whole body is more firm; this material also enhances the anti-slip and metallic. As a smart rugged mobile phone, the most vulnerable place should be the screen. In order to maximize the crack resistance of the BV9700 Pro, the screen adopts the latest five-layer structure design; the outer two layers are solid glass and the inner layer is High color gamut panel, the bottom layer is an aluminum alloy base plate that enhances the overall strength of the screen.
  • New AI cameras, and an external night vision additional one: dual rear Samsung® 16.0MP+ 8.0MP camera with advanced image processing to make fine picture. With AI Beauty technology, it also offers high-quality portraits with bokeh effects and multi-frame image stabilization technology makes your videos smoother and more vivid. The BV9700 Pro's external camera is equipped with a Sony IMX291 Starlight Night Vision Super Sensing, designed for dim and night scenes, with pixels of 2.13 MP, unit pixel size up to 2.9UM, 2.6 times of the phone's main camera sensor. Light plays an important role in photography, and as the unit pixel size increases, more light enters into a single pixel. With the 6P lens of the large wide-angle super large aperture, your mobile phone instantly becomes a night camera, easily capturing the wonderful moments in the dark.
  • New sensors: heart rate, air quality, barometer. More and more people are participating in outdoor exercise, and we hope to monitor our heart rate at any time during the exercise. The Blackview BV9700 Pro provides us with this convenience. We can use this app on the mobile phone to detect your heart rate before, during and after exercise, adjust your exercise intensity in time to adapt to your own sports conditions, and track our health and fitness goals more easily. The built-in pedometer also helps track the number of steps and calories. No matter where we go, the mobile phone is here, also the air has always been around us. With the BV9700 Pro, whether it is in the bathroom, bedroom, living room, working office, etc., just open the air quality testing app,we can know the around air quality. The BV9700 Pro's new barometer is used to locate the height of where we are. In addition, the sensor can also assist GPS for more precise positioning. The barometer can cross-check the detected height and barometric GPS signal data to assist the GPS to measure the height and error navigation does not exist anymore.
  • New processor: Helio P70. The CPU upgraded from previous P60 to the P70, which reduced power consumption by 30%, heat cooling improved by 20%, longer battery life by 15%, and speed up by 13%.
