belloriccofamoso
enable/disable android PIN
Mon Apr 15, 2019 3:47 pm
Hallo
during first installation i had enabled ANDROID PIN, the pin that lock the load of the android , not display lock.
how can i disable this first pin? i didn't find where
sorry
and thank you
Android 8.1.0
Build BV_BV9500Pro_V1.0_20180827
Re: enable/disable android PIN
Mon Apr 15, 2019 9:12 pm
Hi there, such feature is called "secure boot" or "secure start up". Take a look here: https://www.google.com/amp/s/forums.and ... html%3famp
belloriccofamoso
Tue Apr 16, 2019 10:42 am
yes i saw, and i know little android menu.
nowhere i had found how disable secure pin at boot....
of course i no talk about screen lock but the first pin i had enabled douring first installation, i supposed was the screen lock..., no is a secure pin at boot...so i have to put 2 time same pin...
belloriccofamoso
Tue Apr 16, 2019 10:56 am
i found.....
Settings->security->screen lock->PIN
Fabio1979
Thu Apr 18, 2019 12:44 pm
i have the same problem, but i have try to change. when you set a new PIN/Sequence/Other befor set the password the phone ask you if want insert password befor the phone startup. if push NO when the phone startup ask you the password only for remove save screen
i hope i understand correct and write correct.
Ciao
Mon Apr 22, 2019 10:09 pm
i found.....
+1
