Surah69
Auto call recording
Sun Apr 14, 2019 2:31 pm
The phone has a call recorder inbuilt but I have to touch the recording switch all the time can you help me with the setting so I can rec all the calls automatically . or suggest me a auto call recorder with the link compatible with p10000 pro
Thanks
Re: Auto call recording
Mon Apr 15, 2019 9:18 pm
Hi there! Just download one of the dozen 3rd party call recorder apps from the play store ;) they are all compatible!
