-sorry my english is bad-
When new update appear,  i install it. Then my bv9500 got brick..
I search for solution, and i get this
https://www.getdroidtips.com/stock-rom- ... ew-bv9500/
The stock rom that i downloaded from that site is 20180629 rom.. i successfully get my phone back.. but i can't update the rom..
Luckyly i know someone who have bv9500 too..
After i see in the forum the update is working again, i updated his phone.. and trying to create stock rom backup based his phone.. using readback spflashtool and wwr mtk
I successfully create stock rom partition backup.. but failed creating scatter file in the process.. then i used scatter file from getdroid rom that i mention earlier..
The problem is, i must click partition location one by one.. (not automatically loaded)..
But even i must load every partition file one by one.. i finally managed successfully installing the lastest update.
If anyone know to edit scatter file, so that scatter file loaded every partition automatically.. then tell me how..
If someone need the lastest stock rom i created. I will upload it.. but u must load every partition file one by one
