SushkoFF
The problem with 3g
Wed Jul 27, 2016 6:17 am
Hi, when in network settings choose 3g only and the 3g signal is weak then the network will automatically switch to 2.5 g. Can this be fixed?
Re: The problem with 3g
Thu Jul 28, 2016 9:36 am
BV6000 can support 2g /3g /4g network, not 2.5g, and when the 3g network is weak,
it is nature for smartphone to switch to a stronger network.
Best regards,
Admin
