amigabest
Spare parts
Sat Mar 30, 2019 12:26 pm
Dear sirs, unfortunately my P6000 (6+64) was dropped on the groung and the display was broken. The mobile is fully functional, so no problem about this aspect.
The only thing is the touch screen: I need to replace it. Where Can I find this spare? I'm in Italy. I see with Amazon that some kit for P6000 touch screen are aavailable. Are they reliable?
Please, let me know.
with best regards,
Enrico
Re: Spare parts
Sun Mar 31, 2019 9:43 pm
Hi there, Amazon kits are reliable. ;)
amigabest
Re: Spare parts
Mon Apr 01, 2019 9:48 am
Hi there,
thank you very much for your quick reply. Just a last question: any suggestion about a reliable kit and reliable supplier in Amazon about the touch screen replacement part? Thank you.
Enrico.
Re: Spare parts
Mon Apr 01, 2019 7:47 pm
Sure!
1) If possible, Buy a kit wich includes LCD&TOUCH + Frame, as it will be easier to install.
2) Buy directly from Amazon (item sold and shipped directly from Amazon), or from an Amazon 3rd party seller BUT with the item shipped by Amazon. In this way you'll get the best warranty and customer care on such kit.
amigabest
Re: Spare parts
Fri Apr 12, 2019 8:09 am
Thank you for your suggestion.
Unfortunately, a shipment managed by Amazon for this item is not available in Italy. Can you suggest something else? A different site? A reliable supplier?
Thank you.
Re: Spare parts
Sun Apr 14, 2019 1:36 am
You can also buyt it from Aliexpress, it will be cheaper. Just stick to the most and well rated sellers (look at their stars)
amigabest
Re: Spare parts
Fri May 03, 2019 7:11 am
Hi there,
the LCD spare part is now arrived. That's good.
Now I ask you if there is a tutorial (or the like, ex. a list of operations )  in order to show the operation for a safe substitution of the screen.
Searching in internet nothing found about. Can you help me?
Thank you.
B/R
amigabest
Re: Spare parts
Mon May 06, 2019 6:56 am
Hi there,
I watched the videos. Both the videos show how to disassemble the mobile (battery and CPU) but not how to change the screen. The only video I found for screen changing is regardina a BV6000 mobile. Can I follow the BV 6000 procedure in order to substitute the LCd of the P6000? Or there something I need to know in order to not damage the mobile during the operation (ex. glue on the border, screws, heating the glass - which temperature - or the like)?
Thank you.
Re: Spare parts
Mon May 06, 2019 8:11 pm
amigabest wrote:
Hi there,
Thank you.
Yes, it looks similar.
If you don't know how to properly replace the display, i suggest you to contact any phone repair center near where you live. The risk to damage the new display or the phone is high.
