Kooog
Restart problem. Probably powe button?
Sat Mar 23, 2019 7:29 am
Hi there!
Had my 8000 pro for four days. Worked properly til now. Charged phone overnight. After that it shuts of every time i push the power button. If i just wait for the screen time out to go on i can just unlock it with the fingerprint sensor and it works just fine. But as soon as i push power button it shuts the phone down.
Faulty power button maybe?
Re: Restart problem. Probably powe button?
Sun Mar 24, 2019 5:45 pm
Please perform a factory reset and report back if it solves your issue.
Kooog
Mon Apr 01, 2019 9:46 am
Done hard reset. Makes no difference. Everything else works. But when i press power button to switch off screen the shut off/restart etc menu comes up and after a few seconds the phone restarts. Acts just as if the power button is held down.
Mon Apr 01, 2019 8:04 pm
It definitely looks like a faulty power button. Please contact your seller to have your phone replaced/repaired under warranty.
