vicky
camera sound
Mon Mar 18, 2019 7:33 pm
Whenever i click photos on my Blackview BV9500 pro mobile, each time the camera makes sound. Please let me know how to disable the sound.
Re: camera sound
Tue Mar 19, 2019 9:22 pm
Hi there!
I highly suggest you to install the Opencamera App, definitely better than the stock one.
In the Opencamera app you'll find the entry for the shutter sound under settings ;)
Cilone
Re: camera sound
Wed Mar 20, 2019 3:42 pm
blackview_admin wrote:
Hi there!
I agree, but:
wouldn't be better to consider the option to REPLACE the stock app with a better one? Stock App has ridicoulous focus problems... lol :)
vicky
Re: camera sound
Wed Mar 20, 2019 6:31 pm
Hi there!
Hi I have already installed Opencamera App, under the setting i don't find the shutter sound, please let me know how to disable this feature as it's very annoying when clicking the photos each time :(
Tech Addict
Re: camera sound
Thu Mar 21, 2019 2:36 am
Hi there!
I agree, but:
I content that ANDROID has a focus problem.  I have yet to find any Android phone that focuses reliably and consistently without using manual focus and the one device I have used with Camera2 API doesn't even focus to infinity properly when manually focused to that point.
On one device I tried like four or five different camera apps, all performed identically with focusing, indicating it's done in hardware or at the OS/Driver level.  But I could be wrong, I'm no dev. ;)
Re: camera sound
Sun Mar 24, 2019 7:06 pm
Hi there!
In Opencamera app go to settings (click on the wheel) -> more camera controls. You'll fine the shutter sound entry here.
rurounni
Re: camera sound
Sun Mar 24, 2019 9:52 pm
On the BV9500 nonPro, when i open the Camera stock app, i click on the settings whell (left side of the flash) and on the last option i have the option
"Capture Sound". Disabling it removes the shutter sound.
Can you check if the Pro also has it? They should be similar.
Best regards
CallMeColt
Re: camera sound
Thu Apr 25, 2019 1:58 am
Mine has the option to turn off the shutter sound & it is the Pro model. I have the latest update to both the app & the system.
I'd like the option to silence the chirp when tapping the screen to focus as well.
Tech Addict
Re: camera sound
Thu Apr 25, 2019 4:25 am
I didn't realize that got updated. I just realized I've got to go disable all the crApps I'll never use... Again...
Wait....
WHY CAN I NOT DISABLE CAMERA?
