mhockings
BV7000 Wifi won't turn on
Fri Mar 15, 2019 10:39 pm
My wifi has stopped working. When I go to settings and try to turn it on the switch goes to on for about 10 seconds then reverts back to off. When I try to turn wifi on using the shortcut menu found by swiping down nothing happens. I have no wifi. Tried a restart with no luck.
Thanks
Re: BV7000 Wifi won't turn on
Sat Mar 16, 2019 11:28 pm
Hi there, please try to perform a factory reset from the recovery menu:
viewtopic.php?f=192&t=334922
mhockings
Sun Mar 17, 2019 4:35 am
Hi, I performed a factory reset from the recovery menu as suggested. I still have no wifi. My phone is unable to find any networks.
mhockings
Mon Mar 18, 2019 8:40 am
I've tried a reset as described. The problem still exists. There is no bluetooth either
Tue Mar 19, 2019 10:55 pm
Did you try to connect to another wifi network?
mhockings
Wed Mar 20, 2019 7:01 am
I can't turn wifi on. So no networks are available.
Sun Mar 24, 2019 5:47 pm
It looks like your unit got a faulty internal antenna. Please contact your seller to have it replaced under warranty.
