alproterra
Mobile data not responding
Thu Mar 14, 2019 11:14 pm
Hi there, I seem to be having some difficulty connecting to mobile data. My phone is a Blackview BV9000. I have contacted my provider- Virgin Media who have done as much as they could but have now said I need to contact yourselves as they have tried everything their end. The 3G button is showing but it has a cross next to it and won't load any websites. Is there something I need to do with the phone to get it to respond to 3G?
Re: Mobile data not responding
Sat Mar 16, 2019 12:51 am
Hi there. Where are you living at the moment? it looks like a band/country incompatibility issue.
alproterra
Sat Mar 16, 2019 11:04 am
Not sure of that, I live in the UK and my work phone is fine and my old phone before this one was fine too
Sat Mar 16, 2019 11:20 pm
If you live in the UK, all phone bands are working correctly. At this point, your phone internal antenna may got disconnected or damaged. I suggest you to contact your seller to have it replaced under warranty, but before that try to perform a factory reset and change SIM slot.
