Chimera123
Where to buy extra audio - long usb c cable?
Thu Mar 14, 2019 12:40 pm
Can you recommend where to buy another audio - usb c cable suitable for bv6800?
And, please sell it separately on your official blackview stores in aliexpress
thank you
Re: Where to buy extra audio - long usb c cable?
Thu Mar 14, 2019 9:01 pm
Chimera123
Fri Mar 15, 2019 12:42 am
Thank you, Does blackview sell it in Aliexpress too?? Because shipping from Amazon to my country is problematic
Chimera123
Tue Mar 19, 2019 4:09 pm
Thank you! Unfortunately I see that somebody in the comments said that the usb-c is too short for bv9000 so I guess it will be the same for bv6800, this is his picture
https://ae01.alicdn.com/kf/UTB8Qn8RG4HE ... 20x220.jpg
Chimera123
Sun Mar 31, 2019 8:05 pm
Just for anybody who wondering how to do it, I just bought a few regular USB-C to 3.5mm Earphone Audio from AliExpress and cut the plastic to size with knife :) and it works good
I tried to upload a picture but it doesn't work in this forum every time I tried, it shows "HTTP error"
