Guache91
Is it dead? (Powering issue)
Mon Mar 11, 2019 3:41 pm
Hi Blackview community,
I'm not sure my BV8000 pro have survived after living a carnival...
The charging port have suffering water, sand and flour (among others stuffs) exposure.
Since then, It's impossible to charge it. Sometimes the red light appears, but it doesn't turn on any more...
what may be the dysfunction? Which component?
I'll try to fix it here, but I am dubitative that the guys could do it with this specific port...
Should I buy this ? https://www.aliexpress.com/item/For-bla ... 04291.html
Thanks
Re: Is it dead? (Powering issue)
Mon Mar 11, 2019 7:48 pm
Hi there!
From what i can read, it seems that the usb charging port may be dirty. I suggest you to carefully clean it with a needle and isopropilic alchol.
If accurately cleaning it can't solve the issue, you can replace the charging board with the one you linked ;)
Guache91
Thu Mar 14, 2019 12:09 am
Hi!
After check, it appears that the battery is dead... How can i find one without waiting two months for the deliver? There is no battery of this model/type in the american continent ? Any regional provider ?
Thanks
Thu Mar 14, 2019 12:29 am
Nope, unfortunately. But you can chose a faster shipping way on AliExpress paying more.
Guache91
Wed Apr 24, 2019 5:36 pm
Hi !
I changed the battery, but it still doesn't charge... help...  I definitely need a new plug board ? ...
Fri Apr 26, 2019 1:56 pm
Guache91 wrote:
Hi !
Yes, as i suggested you in my previous posts...
