Ekavun
Multifunction Key, double click and single click issues
Sun Mar 10, 2019 1:16 pm
My multifunction key is mapped to open 2 different apps, depending on whether I perform a single tap or a double tap. Single tap = app1, double tap = app2.
However, the behavior I'm noticing is one where the phone simply switches back and forth between both applications. In other words, if I perform 2 single taps with 10 seconds apart, my phone will go from app1 to app2, where the expected behavior should be that it stays on app1.
It is as if the timer for a double tap was set to infinite. So 2 single taps many seconds apart will be considered as a double tap.
Can you check?
Re: Multifunction Key, double click and single click issues
Sun Mar 10, 2019 8:16 pm
Guys, can anybody else confirm such issue?
sams
Mon Mar 11, 2019 3:39 pm
Confirmed, I have screenshot on double-click and almost every time I unlock my phone I have to cancel a screenshot. Super annoying.
