Sun Mar 10, 2019 9:00 pm
Tue Mar 12, 2019 10:05 am
Tue Mar 12, 2019 11:42 pm
waerloga wrote:Further research has revealed this is a common issue, different ringtones for each SIM is a built-in Android feature but the controls for this are commonly not included by dual-sim phone manufactures.
I found two apps to address this; DualSimRinger by mdn worked
https://play.google.com/store/apps/deta ... lsimringer
I had to change the 'Call Mode' to '1' in the settings. This app currently only works for calls, not SMS.
Kim
