rafii6311
Need P10000 Pro ROM
Wed Mar 06, 2019 2:52 am
I managed to somehow brick my phone and now i need the stock firmware file to fix it.
Thanks!
Re: Need P10000 Pro ROM
Wed Mar 06, 2019 3:49 pm
Hi there, unfortunately it isn't officially available to be downloaded and flashed.
rafii6311
Tue Mar 12, 2019 2:24 pm
Finally got it to work again.
I flashed this ROM using SP Flash Tool.
https://mega.nz/#!wNcRFIoS!dD3d3KQlVMEW ... v55L6LVAHI
After flashing, everything worked except Calling/SMS/Mobile internet. Somehow the IMEIs got lost. (*#06# shows empty dialog)
I reset the (default, that the phone got shipped with) IMEI by using the build in "EngineeringMode" App.
You get into that typing *#*#3646633#*#* or simply searching the PlayStore for EngineeringMode App.
Under Telephony->GPRS you can set your IMEI, after pressing "Write IMEI", its important to reboot.
Now everything is working again.
I AM NOT RESPONSIBLE FOR ANY DAMAGE THAT IS CAUSED BY THIS TUTORIAL.
Even tho, in my opinions its pretty impossible to permanently brick MTK Phones.
Tue Mar 12, 2019 11:30 pm
Such rom hasn't been officially released from us. It as a backup of unknown origin. Flash it at your risk!
P_E_T_O
Fri Mar 15, 2019 12:38 pm
so release original rom for such cases!!
JPRMB
Sat Mar 16, 2019 9:25 pm
hello,
i'm waiting for your official realease too ...
no release, no business !
luigiluigi
Tue Sep 17, 2019 7:22 am
Aggiornamento a Oreo arriverà.
È stato promesso.
barracudda
Tue Jan 28, 2020 5:30 pm
Hello.
Original backup of rom ANDROID 8.1.
only use flashtool and this rom.
fixes the red chinese letters in top right screen if you downgraded to android 7.1.1 like I did.
android 7.1.1 ROM has MTK ANDROID TOOLs so you can fix IMEI under GPRS MENU then install. then download and install this
BLACKVIEW P10000PRO ANDROID 8.1 ROM   After you install it you can update one via wireless. You are welcome :P
https://mega.nz/#!wNcRFIoS!dD3d3KQlVMEWVTsJO6I6WVzTMEDAdbIBGv55L6LVAHI
wilopezn
Tue Aug 25, 2020 12:57 am
Hi, ROM download p10000pro it's ready?, Two years AND nothing.....very bad, very sad.
Tue Aug 25, 2020 8:30 am
Hello, sorry for the inconvenience, please contact the after-sale department support02@blackview.hk
