Ekavun
Fingerprint Gestures
Tue Mar 05, 2019 10:03 am
Hello there,
I'm a blind user and rely on Talkback to use my BV6800.
Talkback has a bunch of functions that can only be accessed using gestures on the fingerprint sensor.
They do not work, and I am either suspecting this to be an issue with Android 8.0 Oreo,, or a block by BlackView on the OS.
1. If it's Android, how can I update to 8.1 or 9?
2. If its BlackView, how can I remove that limitation?
Gestures require me to swipe in different directions on the fingerprint sensor.
Best,
Emrah
Re: Fingerprint Gestures
Wed Mar 06, 2019 3:50 pm
Guys, can anybody else confirm such issue?
Ekavun
Sun Mar 10, 2019 1:10 pm
Hello!
There are a few apps on the App Store that allow you to use Fingerprint Gestures that you can use to verify my issue.
Example: https://play.google.com/store/apps/details?id=com.catalyst06.fingerprintactionpro&rdid=com.catalyst06.fingerprintactionpro
I believe the Fingerprint API has been disabled on the Firmware. Can you look into enabling it for the next update?
Sun Mar 10, 2019 8:13 pm
Unfortunately i need some more users to confirm such issue.
