Pizzalover
Phone died suddenly - not charging - battery connector broken off
Fri Feb 22, 2019 10:53 pm
Hi guys.
My trusty old BV6000 suddenly died, and it would not take charge.  Only 5V 120mAh for 6 seconds, then nothing.
I opened the phone, and the connector on the battery cable was stuck on the motherboard.
I gently lifted the connector away from the motherboard, but there seemed to be glue or similar inside, so the motherboard side lifted slightly.
Have any of you had similar experiences?  I have ordered a new battery and will try so see if that fixes the issue.
On a side note, I found a small screw inside, but all screws inside are present.  I guess the factory included it as a spare. :)
Thanks.
Thor from Norway.
