alfredoproma
Problem back camera 16 MP don't work autofocus is not clear
Fri Feb 22, 2019 10:07 am
I have a problem with my smartphone bv9000 the back camera 16 MP don't work , when I try to photograph an object both near and far the autofocus does not work and the photo is blurred.
when I take a picture it's not clear when I touch the screen the lens focuses, but it does not come out clear, the lenses are clean and the phone is working properly.ImageImage
between the tests carried out I also tried the factory reset
I await your response.
thank you
alfredo pulitano
Tbird00
Re: Problem back camera 16 MP don't work autofocus is not clear
Wed Mar 06, 2019 12:31 pm
The upper camera probably doesnt work,you can try and cover it with your finger while taking a photo to check it out.`
I have the same problem when i upgraded my phone to the latest Android OS and im waiting for 6 months for an answer......
alfredoproma
Fri Mar 08, 2019 6:27 am
Admin please answer me
Whip85
Sun Mar 10, 2019 12:37 am
Good luck getting any answers. No drive to actually solve issues.
alfredoproma
Mon Mar 18, 2019 11:50 am
Can anyone tell me the model of the rear camera that I would like to try to replace
alfredoproma
Mon Mar 18, 2019 11:51 am
grazie
Johari
Sat Jul 04, 2020 6:50 am
hi bro,
i got this problem also.. you try factory reset.. than install OPENCAMERA from playstore. n try open the app.. over there got symbol camera. change to ID2.. n camera okey already... can email i can help you..
johari.seller56@gmail.com
Umar Husseina
Mon Jul 06, 2020 6:06 am
I have a problem with my blackview A80pro, i can't update it but the camera is nice and the screen have started developing issues, I'm scared if there is anyway i can swap it with other product.
WSGolem
Wed Sep 02, 2020 1:32 pm
I also have this problem more often, it is enough to close the camera app in the task manager and restart the app.
