Joaquinconti
battery discharge bv8000 pro. system 20180522. android 7.0
Thu Feb 21, 2019 2:08 pm
Hello! I have a bv800prp with version 20180522 and the battery lasts no more than 8 to 10 hrs, I need a solution. It should be noted that it has been restarted from the factory.
I await your prompt reply.
Thank you
Re: battery discharge bv8000 pro. system 20180522. android 7.0
Sat Feb 23, 2019 3:00 pm
Hi there, please perform a factory reset from the recovery menu:
viewtopic.php?f=192&t=334922
Then report back if this solves your battery issue ;)
