fabian.chile
Problems after last update
Thu Feb 21, 2019 1:21 am
after last update there are signal problems, and equipment is blocked for no reason. BV9500PRO
Actual version
BV_BV9500Pro_V1.0_20180827_20190116-1454
Re: Problems after last update
Thu Feb 21, 2019 10:17 am
I can't properly understand what the problem is with such description...... but i want to remember you that PERFORMING A FACTORY RESET AFTER EACH UPDATE IS HIGHLY RECOMMENDED. So, please, do it. ;)
fabian.chile
Sat Feb 23, 2019 12:09 am
Again!!!! After last update , the phone is signal down any moment, and with it lock......if a performance reset....what happen with my photos, videos, application???? I thing that its not a Solution!!!!
Sat Feb 23, 2019 3:25 pm
A factory reset will ERASE everything on the phone, all your personal data, photos, videos and applications. You'll have to backup them. Google backup will help you with that.
This is the only solution, or a necessary step to try to understand what happened to your phone.
Carlos Angel
Sun Mar 03, 2019 1:39 am
hi there,   same happens to me on just one of the sim cards,  i have issues connecting to 4g on Movistar Colombia.   is there anyway to roll back to previous version which was working very well?  i am not having the same problem with sim number 2.   i already did a factory reset and didnt  work. :roll:
Sun Mar 03, 2019 5:05 am
Please change sim slot, perform another factory reset and report back.
Carlos Angel
Mon Mar 04, 2019 12:35 pm
Ii did complete another factory reset, the problem persists on 4G LTE Movistar,   on other sim cards and networks it works fine.  is there any option to roll back? or have a new update with this sorted out?  I am really struggling and desperate to have the working well for my work.
Mon Mar 04, 2019 9:37 pm
Unfortunately you can't roll back at the moment, as firmware files for flashing haven't been officially released. The issue seems to be related to such carrier, it may be an APN incompatibility.
Carlos Angel
Tue Mar 05, 2019 12:24 pm
I spent some time with technicians from the operator. the problem seem to be on one of the bands ..  How can I be sure all the bands are open for Colombia?
Wed Mar 06, 2019 3:47 pm
These are the supported bands in Colombia:
https://www.kimovil.com/es/frequency-ch ... iew-bv9500
