Snooker
BV9500PRO - Time out too short
Sun Feb 17, 2019 5:00 pm
Hi
Since the last update, a time out has been added on intercom module. Transmission is interrupted after something like 30 seconds. This is too short for a normal communication. Could you planned to add more time or a user setting reading this issue?
Brgds
Re: BV9500PRO - Time out too short
Mon Feb 18, 2019 6:50 pm
Can you please perform a factory reset and check again? A factory reset after each firmware update is HIGHLY recommended!
Snooker
Thu Feb 21, 2019 8:15 pm
Hi
I did a factory reset.... The situation is worst than before. Intercom is totally deaf in DMR reception now. It's still operated in DMR transmission, and fully operative in analog mode.
DMR decoding seems to be dead !!!
Please keep us posted with a reliable solution to recover a nominal situation with intercom module.
Brgds
Sat Feb 23, 2019 3:29 pm
Snooker wrote:
Hi
Brgds
Please try to perform the factory reset from the recovery menu:
viewtopic.php?f=192&t=3349223
