ianas
h.265 encoding
Tue Feb 02, 2016 4:13 pm
Crown is a mt6592 device
According to Mediatek the mt6592 soc supports h.265 encoding, the build-in camera app only does h.264 is there a way to record video in h.265 natively or do I need an extra video app, does enybody know what video app records in h.265?
h.265 is 2-4 times more efficient then h.264,
From
http://www.mediatek.com/en/products/mob ... e1/mt6592/
Features
Octa-core (1.7GHz or 2GHz) ARM Cortex-A7 processor
ARM Mali GPU
UMTS / HSPA+ R8 / TD-SCDMA / EDGE / LTE
Dual-band 801.11a/b/g/n, Bluetooth, GPS, FM receiver
Full HD display controller
16MP image signal-processor
H.265 Ultra HD video record & playback
also mt6592 should support google's vp9 codec that one should be better then the h.264 again anyone knows how to record video in vp9?
From
http://www.mediatek.com/en/news-events/ ... -platform/
The MT6592 features a world-class multimedia subsystem with a quad-core graphics engine, an advanced video playback system supporting Ultra-HD 4Kx2K H.264 video playback and support for new video codecs such as H.265 and VP9, a 16-megapixel camera and a Full HD display. The SOC also features MediaTek ClearMotion™ technology for automatic frame-rate conversion of standard 24/30fps video to high-quality 60fps video for significantly smoother playback.
tanks
ianas
Re: h.265 encoding
Tue Feb 02, 2016 4:30 pm
I did some googling and it seams only lollipop's native camera app has h.265 encoding I couldn't find any other info about h.265 on android, it seams a shame Crown has hardware support for h.265 but there is no way to use it :(
I may need to get/poprt cm 12.1 on Crown to use it's full potential
