MylenaBorges
do not care
Tue Feb 12, 2019 10:47 pm
Good Night!
I have an 8000 pro that does not turn on anymore, and when connected to the battery the flashlight comes on and the screen is still off.
Re: do not care
Wed Feb 13, 2019 5:30 pm
Hi there! Unfortuntately it looks like your device got a bad hardware fault. The only thing you can do is to contact your seller to have it replaced under warranty.
