BV9500PRO
MY DEAR BV9500PRO is dead
Tue Feb 12, 2019 6:05 pm
HELLO :) I have a BV9500PRO and I was trying to factory reset my phone in android system setting. just after I reset my phone is dead no doubt. because Its not turn on anymore. I held buttons but every button is not working too. (It means blackview logo is not appear in screen whether how long I pressed button or not)    T.T   I really wanna get back my BV9500PRO can anyone help me please?   Thank you
Re: MY DEAR BV9500PRO is dead
Wed Feb 13, 2019 7:17 pm
Hi there!
Please try to perfom a factory reset from the recovery menu. Follow this tutorial:
viewtopic.php?f=192&t=334922
...and report back!
BV9500PRO
Fri Feb 15, 2019 7:32 am
Thank you for reply!  sorry as I told you all of the buttons not working anymore T.T  I pushed some combinations of buttons and every each button but not working. It is totally "dead"
Fri Feb 15, 2019 10:33 pm
Unfortunately there's nothing more to do except contacting your seller to have your device replaced under warranty :(
BV9500PRO
Sat Feb 16, 2019 2:08 pm
so sad.... T.T
Sat Feb 16, 2019 11:01 pm
Faulty units may happen, although it's really annoying.
Users browsing this forum: Google Adsense [Bot] and 1 guest
