Deau
Speaker sound is muzzled
Fri Feb 08, 2019 1:29 am
Hi, my loud speakers sound is muzzled and sound is not clear. I only used phone for few months. What can I do? Do you have repair center in Hong Kong?
Thanks
Re: Speaker sound is muzzled
Wed Feb 13, 2019 7:29 pm
Hi there, it looks like your speaker is faulty.
I highly suggest you to contact your seller to have it replaced under warranty.
Here you can find official dealers/repair centers (just in case your seller doesn't want to honor warranty terms):
http://www.blackview.hk/global-agents/
If you are handy and don't mind about losing warranty, here you can find the replacement part (back cover + speaker)
https://www.aliexpress.com/item/BLACKVI ... st=ae803_3
Deau
Tue Jun 11, 2019 3:40 am
I ordered this from Indigogo.  Where is the repair center in Hong Kong I can take this to?
Thanks.
Wed Jun 12, 2019 1:31 pm
Thanks.
The nearest official one is in Singapore.
bpz1970
Sat Jun 15, 2019 11:29 am
Mine has also this same problem. It happened a month ago. Suddenly some sound distortion was heard from the rear loudspeaker intermittently. Then, a week ago all the sound coming from the rear loudspeaker was distorted with a "brrrrrr" noise coming out for a second after the sound from the speaker was stopped. As of today, no sound is coming out front the rear loudspeaker (the speaker is dead). I contacted the seller (I bought it from Amazon) but I haven't received a satisfactory answer yet. I plan to void the warranty and to open this device to see what's happening. I have ordered a new speaker and a new usb board (since the speaker terminals are soldered to this board) from AliExpress. I'll let you know about the results.
From my point of view, the Achilles heel of BV rugged phoned is the speaker design. The same issue happened to a BV8000 pro I owned. If the dust of the environment has metallic particles, then the speaker is doomed.
bpz1970
Tue Jun 18, 2019 12:07 am
After opening the phone, I saw that the cause of the problem was that the red cable of the loudspeaker showed signs of cold soldering (the end that goes to the speaker, because at the PCB it was ok) and the black cable was cut (!).
I replaced the loudspeaker and voilá!
Problem solved.
Tue Jun 18, 2019 9:29 am
Problem solved.
Great! ;)
Deau
Fri Jun 21, 2019 6:34 am
Sorry to hear you have same problem.  Please do let me know if it works.  One thing about blackview is that their maintenance service is like non-existing for most places so can't really use their warranty...:(
Fri Jun 21, 2019 9:36 am
The seller is the one who manages warranty terms, refunds, repairs, replacement and so on.
bpz1970
Fri Jun 21, 2019 2:28 pm
As I stated on a previous message, I had to replace the speaker. The cause of the fault was cold soldering on the red + cable and broken black - cable. Now the phone is working as it's supposed to.
