After searching through this forum I did not find any solution or people having the same issue.
When I try to open my camera app and to connect to the front camera it just stops working, similarly, other apps freeze or close.
It does not seem to be due to several apps using it at the same time and I've seen that people have had similar problems in the past with other models, any tips on how to manage this problem?
Thank you in advance!
