AleP
Speaker Replacement Tutorial
Mon Feb 04, 2019 11:01 am
I accidentally broken the speaker of by Bv8000 Pro, can anyone tell me if is possible replace it without problems or risk?
Thanks!
kavedel
Re: Speaker Replacement Tutorial
Mon Feb 04, 2019 7:46 pm
I already done this three times if you talk about the main speaker. The best thing you can do is search for a Russian video in YouTube which shows how to change the charging board and follow from there until the speaker is visible. The admin has given the link in some different threads, maybe he can give it now too. The thing you should be careful of is to have the new speaker well sealed after you replace it if you care about water proofing your phone again. I used a special silicone for this just to be safe.
AleP
Mon Feb 04, 2019 7:48 pm
Thanks, what type of silicone you used?
kavedel
Mon Feb 04, 2019 9:42 pm
I used an MS-polymer product.
AleP
Tue Feb 05, 2019 6:47 am
But how can I remove the speaker? Is it glued with silicone? And how should I fix it only with silicone, or have screws
kavedel
Tue Feb 05, 2019 10:46 am
It stays in place just by the silicon type glue it already has. You remove that and then you just pop it out and put the new one in its place and cover the small gaps with silicone.
Here is the video I was talking about https://youtu.be/_gqXcHqiPQA?t=454 if you see it closely at 7:34 you will see a thin white line around the speaker. You remove that to take out the old speaker.
