vollli
BV 8000 pro Speakerproblems
Sat Feb 02, 2019 2:18 pm
I have 2 BV8000pro and with both phones problems with the rear Laustsprecher.
Both phones were purchased through EBAY and the vendors did not report warranty claims.
The first one was bought on 08.08.2017 at the seller @1superbest1 and was broken in April 2018.
The second one was bought on 12.04.2018 at the store @topsuche and is now also defective, loudspeaker rattles and is no longer to understand.
I would like to buy a BV 9500pro or 9600pro, but I am disappointed by the customer service and will probably go to another manufacturer.
I ask for a proposal yur warranty processing !!!!!!!!
Yours sincerely
Re: BV 8000 pro Speakerproblems
Thu Feb 07, 2019 10:35 pm
Hi there. eBay isn't always the best place to buy things (as you noticed...).
The seller will manage warranty terms with Blackview phones, so BE SURE to buy your phone from a TRUSTED seller.
I recommend Amazon, as it has the best customer care ;)
