Fabio1979
Speaker Volume
Sat Feb 02, 2019 9:28 am
Hello
i have my BV9500 pro from 4 months.
i remember that first time the volume of speakers is very High and good quality. I play music in my room without problem at no max power.
now i put max power volume but is not same, and the quality of sound is less.
What can i control ?
thank you
Re: Speaker Volume
Thu Feb 07, 2019 10:11 pm
Hi there, first perform a factory reset and check again. If this doesn't solve your issue, you speaker may be dirty or it became faulty.
