brodtmashine
Random restarts / random Power off / Android System may be corrupt
Wed Jan 30, 2019 11:51 am
Hello, i have the BV6800 ro and following problems.
-Sometimes it just powers down without any reason.
-Once I took it out of the pocket and saw a screen "Android may be corrupt" Options: try again (didn´t work) or factory reset.
-Sometimes it just restarts witout any reason.
Is there any solution for my problem?
Newest Update via OTA is installed. Phone is not rooted or anything else. Just some Apps installed. Same config ran stable on my BV6000.
Re: Random restarts / random Power off / Android System may be corrupt
Sat Feb 02, 2019 2:39 am
Hi there, unfortunately it looks like your phone as a bad hardware fault. You'll have to contact your seller to have it replaced under warranty.
aztec165
Thu Oct 10, 2019 8:51 am
i meet the same issue , do you have a solution?
best regards
i use a BV6000 since the midlle of october 2016 , unstoppable phone !
grAwp
Thu Oct 17, 2019 4:55 am
A factory reset didnt help ?
