  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
AleP
New Android Oreo firmware found on 4PDA (TESTING)
Tue Jan 29, 2019 5:52 pm
Hi guys, now I found a new Android 8 firmware in 4PDA forum, here is the link to the forum, to the download, and to a tutorial, unfortunately all this links contains russian pages, I am not responsible for any damage to the device.
Good Luck!
Firmware version: V1.1_20180914_20180914_1420
TUTORIAL: https://youtu.be/B-SjmUxuUMU
DOWNLOAD LINK ON YANDEX DISK: https://yadi.sk/d/PWwgA4Ig8CNE0Q
DOWNLOAD LINK ON GOOGLE DRIVE: https://drive.google.com/file/d/1Z9ahPf ... EtrSo/view
FORUM THREAD: https://4pda.ru/forum/index.php?showtop ... ry81215386
Can anyone try to flash like is shown in the video and report if this firmware works? Thanks.
And remember to backup before flashing and perform a factory reset after flashing.
bilyj
Re: New Android Oreo firmware found on 4PDA (TESTING)
Sat Feb 02, 2019 6:57 pm
I use this firmware. Upgrade my phone yesterday, at night. I have no time today to test them. But it seems like battery live longer.
AleP
Sat Feb 02, 2019 7:06 pm
Good!
AleP
Sat Feb 02, 2019 7:08 pm
AleP wrote:
Good!
Can you send a screen of the deep sleep percentage with CPU SPY? as soon as you can, thanks.
bilyj
Sun Feb 03, 2019 9:42 pm
AleP wrote:
AleP wrote:
Good!
Morning and evening screens
AleP
Sun Feb 03, 2019 9:50 pm
Very good, what type of use you did? Did you find any problem?
Rgaspar
Sun Feb 03, 2019 11:08 pm
at first day of use,it seems that battery usage is normal (the same as android 7) and is charging quick (a lot faster than official rom). i liked camera interface and it seems very stable. tomorow i will test low light photos and bt connection
bilyj
Mon Feb 04, 2019 11:08 am
If i correctly understand your question: mainly I used Facebook, Chrome, WhatsApp, Telegram , phone calls, Gmail and Google maps at short time. But yesterday I drive a lot between the city's, so phone all time search the cell network.
No new problem. But some problems from firmware-2018062921 still present:
- If chose "Ask every time" in "Settings/Network & Internet/Sim cards/SMS message/Select SIM card". Sim card work normal , but cell phone always show "Sim card changed", it's happening when phone connect to another base transceiver station.
-Some application not supported in google play, but with Android 7 it was supported.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 9
