szankatb
Pedometer problem
Mon Jan 28, 2019 10:46 am
I am using google fit with my BV9500 pro and I noticed I have very few steps at the end of the day however the phone was in my pocket all day.
Is there any way to check the work of the pedometer in the settings?
Can it be a sensitivity problem?
Thanks in Advance!
Re: Pedometer problem
Tue Jan 29, 2019 6:53 pm
As you can see here (https://www.google.com/search?biw=1920& ... pVy_u98OlY ) it seems that the google fit apps got serious bugs.
Some things you can try:
- Clear the Google fit app cache/data storage
- Activate track activity metrics from the app's internal settings menu
- Clear all the app permissions and enable them again (storage permission and so on... you can do that by going to phone settings -> apps)
