Mezzafella
Android Auto makes bv9000pro auto reboot
Thu Jan 24, 2019 7:30 pm
I m having problems while connecting my bv9000 via USB cable to my uconnect radio. When i try to start the configuration for Android Auto and i connect my Phone to the radio with the cable, my bv automatically reboot.. With my previous Phone all worked fine. I tried to reinstall the app, reset the phone and the radio, different cable, but anything worked.. Is there a a Solution?
Re: Android Auto makes bv9000pro auto reboot
Fri Jan 25, 2019 8:09 am
Hello, maybe the current supply/volts coming from the car is not suitable and the phone goes into protection.
Best regards,
Staff BlackView
Lezzeti
Thu Feb 14, 2019 9:55 pm
It worked fine on Android 7.1, but not after OTA upgrade. And I measured my car's usb port with a voltmeter, nothing wrong there.
